Does oil analysis prevent machines from wearing or failing? Of course not! Knowing a machine is wearing or that conditions exist leading to machine wear and failure are not factors of prevention. The reason I am making such an obvious point is that I constantly witness plants that go to great lengths to monitor the condition of their equipment, but do nothing to address the problems or else don't understand the presented information. While this problem may occur with many condition monitoring technologies, the focus of this discussion is limited to oil analysis, or more specifically, solid particle contamination.
The Appearance of Particle Contamination … Now What?The second step is to employ the appropriate methods to achieve the identified goals. Particle contamination control has several components, but it begins with good lubricant storage, handling and application methods. New oil is a common source of particle contamination because it is typically dirty upon arrival. In the average plant, new oil is often further contaminated by being dispensed into a dirty container with unsanitary transfer equipment, and finally applied to the machine through a soiled funnel. By properly storing, filtering and applying new lubricants, along with the use of simple contamination exclusion methods such as high-quality breathers and seals, an appropriate level of cleanliness can often be maintained for even nonfiltered systems. When these exclusion methods are insufficient, methods to remove contaminants must be used. Contamination removal techniques include portable filtration, permanently mounted off-line filtration and upgrading active system filters to best possible level of performance for a given system. Of course, it is more cost-effective to practice good contamination exclusion methods, and therefore exclusion should be the first method considered.
If the Info is Inaccurate, Why Bother?Good oil analysis is not necessarily good lubrication. It is however, an important part of the lubrication program and is essential for ensuring the proper operating conditions exist to yield the highest level of reliability and machine life. This is the essence of proactive maintenance.
