When Filters Burn: Uncovering Electrostatic Discharge in Ammonia Compressor Lubrication Systems
Rob Simmonds
For more than twenty years, oil analysts examining ammonia refrigeration compressor samples have been staring at the same strange forensic trail: streaks of carbonized lubricant, heat-melted metallic fragments, fractured glass fibers, and debris patterns that made no sense when viewed through the lens of normal mechanical wear. These signatures appeared again and again in plants, bakeries, food processors, and cold storage facilities.
Whatever was damaging these compressors was doing it quietly, consistently, and largely unnoticed.
The investigation that followed—supported by real field samples and a rare series of experimental filter modifications—reveals a failure mechanism hiding in plain sight: electrostatic discharge (ESD) occurring inside the lubrication system. This article follows the clues from the earliest oil samples to the final filter design, showing how one facility’s willingness to experiment uncovered a root cause that may be far more widespread than previously known.
A Mystery in the Oil: When Contamination Doesn’t Behave Like Contamination
The first clue came from the oil itself. Remote-site compressors often send samples to the lab with little contextual information, so analysts rely heavily on what they can see under the microscope. At first glance, many samples looked like classic contamination cases—darkened oil, an abundance of particulate matter, and even glass fiber fragments. Routine advice followed: drain the oil, replace the filters, verify lubricant cleanliness.
But the debris patterns refused to fit the script.
Under ferrography, analysts saw carbonized spheres and string-like residues, blue-black metallic particles showing clear signs of melting, and filter media fragments shattered in ways that didn’t align with mechanical stress. These were signs of intense, localized heat, not slow degradation. And nothing in the compressor—no bearing, seal, or rubbing surface—could generate the 10,000–20,000°C temperatures required to produce such damage.
These clues pushed the investigation toward a different kind of failure altogether—one rooted in electrical energy, not mechanical wear.
A Breakthrough at a City Bakery
Wear Debris Image
This image at 100X indicates the average wear debris and contaminants deposited on the analysis filter from 1 CC of the sample forced through the 3-µm Membrane Analysis Filter.
Roughly twelve years ago, the mystery took a sharp turn. A bakery operating multiple screw compressors through a shared oil reservoir opened the “fresh oil” tank and discovered nearly five centimeters of sludge: dirt, organic debris, moisture—the predictable result of a badly sealed lid.
Cleaning the reservoir fixed the immediate contamination issue, but it raised a larger question: if such an obvious problem could go unnoticed for years, what other hidden mechanisms might be quietly attacking these systems?
That question led researchers to revisit their backlog of unusual wear patterns and investigate whether the damage they were seeing was consistent with electrostatic discharge events inside the filters themselves.
Why Non-Conductive Compressor Fluids Become Electrically Dangerous
Ammonia compressor fluids, like many refrigeration lubricants, are non-conductive. As they circulate at high flow rates, they strip electrons from pipe walls, bearings, filter housings, and other metal components. The fluid builds electrostatic charge the same way hydraulic oils do in high-velocity return lines.
Once the charge exceeds 300–400 volts, it arcs—instantly and violently—to the nearest grounded metal component.
Noria Chart Volts
And this is where filter construction becomes a problem.
Standard filters use a combination of:
  • A conductive steel core
  • End caps bonded to the core
  • A non-conductive media pack (polymer fibers, glass fiber, epoxy-bonded mesh) electrically isolated from the core
In other words, the media is floating electrically. It accumulates charge but has no safe path to ground. The result is a miniature capacitor inside the lubrication circuit—one that discharges directly through the media, destroying it from within.
This is why carbonized lubricant, melted fibers, and metallic arcs kept appearing in oil samples. The compressors weren’t wearing out the filters.
The filters were being cooked by excess electricity.
A Rare Opportunity: Four Experimental Filter Designs
Most plants never get the chance to test multiple filter designs side-by-side under identical operating conditions. But when a freezer facility partnered with its service company and filter supplier, a unique test series unfolded. Four filter configurations were installed sequentially, each attempting to ground or de-insulate the media differently. The lab was dubious that any differences could be made to the ESD charging, since Pall Corporation had completed a series of tests in the 1990s using copper earthing grids in the pipe work and the earthing grids did not affect the fluids ESD charge either upstream or downstream of the copper grids.
Stage One: Polymer Fiber Media (10–25 µm)
The first upgrade had already occurred; the service company had replaced glass fiber filters with polymer fiber media to reduce fiber shedding. While this solved one problem, the microscope told a different story: carbonized lubricant, melted wear particles, and arcing residue remained pervasive throughout the filter.
ESD was still occurring inside the media pack.
Stage Two: Adding Earthing Straps
Next, the manufacturer added grounding straps to the filter housing. At first glance, this seemed promising. But microscopic analysis of the steel core showed clear arc trails—hair-thin grooves burned into the metal.
Because the media pack was still electrically isolated by epoxy, the grounding strap was essentially grounding the wrong component. The internal layers continued to build charge and discharge violently.
Stage Three: Stainless Steel Mesh Media (5 µm)
Switching to stainless steel mesh introduced conductivity into the media itself. This significantly reduced the severity of arcing, but not the occurrence. And the tight 5 µm rating created a new issue: gelled, arc-damaged lubricant rapidly blocked the mesh, causing over-pressure trips.
In short, the filter worked poorly hydraulically.
Stage Four: Fully Grounded Stainless Steel Assembly
The final design was the true breakthrough. Here, every component—mesh, core, end caps—was spot-welded together, then bonded to a single grounding strap. The entire filter became one unified conductive structure.
This configuration finally eliminated floating potentials, giving static charges a safe, low-resistance path to ground. The results were immediate and dramatic.
Field Performance: What Changed When the System Stopped Arcing
Before the fully grounded filter was installed, the compressors required fluid top ups roughly every three weeks due to rapid darkening, varnish formation, particulate loading and oil throwing where the fluid was lost in the system due to degradation. Across four compressors, this added up to approximately 80 liters of waste fluid annually, plus the associated labor.
Once the grounded 5 µm stainless assembly went in, fluid condition shifted noticeably:
  • The oil remained cleaner and lighter for two months, instead of degrading in three weeks.
  • Metallic wear debris dropped to minimal levels.
  • Carbonized residues decreased.
  • Oil throwing ceased & fluid top-ups fell by 75 percent.
The only drawback was the tight 5 µm media, which still clogged prematurely—not because of ESD this time, but because gelled, previously damaged lubricant had nowhere to go. The next logical step is a fully grounded 50 µm stainless media, capable of maintaining conductivity without becoming a bottleneck.
What This Means for Reliability Professionals
Many ammonia plants struggle with recurring lubricant darkening, unexplained filter failures, varnish formation, or wear debris that doesn’t fit traditional modes. This study strongly suggests that electrostatic discharge is an under-recognized root cause.
ESD inside lubrication systems can:
  • Carbonize lubricant in microseconds
  • Melt metallic surfaces
  • Shatter filter fibers
  • Deposit conductive debris downstream
  • Accelerate oxidation and varnish formation
  • Increase bearing and seal wear indirectly
At first glance, these effects look like contamination or oxidation, but they originate from a fundamentally different failure mechanism.
The results of this investigation offer a new path forward—one based on conductivity and grounding, not finer filtration or more frequent oil changes. The early field data shows clear improvement, but one more filter trial is needed to validate long-term effectiveness with a larger mesh size, as noted by the editor.
Conclusion: A Hidden Failure Mode Worth Bringing Into the Light
The evidence across all four filter configurations makes one truth hard to ignore:
ESD is real, it is destructive, and it is likely far more common in ammonia compressors than the industry currently recognizes.
By modifying filters to safely dissipate charge, it is possible to improve oil life, reduce maintenance frequency, and prevent the internal burning that has been silently damaging systems for years.
This work began as a search for the source of strange debris in oil samples. It ended by revealing a root cause the field has largely overlooked—and a promising engineering solution that deserves continued testing.
If your compressor oil is darkening too quickly, if your filters fail mysteriously, or if lab results show melted or carbonized debris, it may not be oxidation, wear, or contamination at all.
It may be electricity.
