Why Machinery Lubrication Conference & Exhibition 2026 Is the Moment the Lubrication Community Has Been Waiting For
Thirty years ago, Noria Corporation set out to do something the industrial maintenance world hadn't prioritized: take lubrication seriously.
Not as a footnote in a reliability program and not as a task assigned to the newest technician on the floor. As a discipline with its own standards, its own credentials, and its own community of professionals who understood that the difference between a machine that runs and a machine that fails often comes down to decisions made long before anything breaks.
Since then, Noria has trained more than 135,000 maintenance and reliability professionals across the globe, published Machinery Lubrication for over 30 years, and built one of the most comprehensive lubrication knowledge bases in the industry. When Noria says it understands what's happening on plant floors, it’s speaking from three decades inside this community.
And what this community has been asking for, consistently, is a dedicated event. One where every session, every exhibitor, every hallway conversation is aimed at the same discipline.
That event is back. Machinery Lubrication Conference & Exhibition returns October 27–28, 2026, in Tulsa, Oklahoma.
We Know This World
How much did your engineering or trade program cover lubrication? For most practitioners, the honest answer is a day or two, maybe less. The people who truly understand this discipline learned it on the job, often without formal support, figuring things out in real time on equipment that couldn't afford mistakes.
Noria has been in that gap for 30 years. Training the practitioners, publishing the research, building the knowledge base that fills what formal education left out.
So when Bennett Fitch, president of Noria Corporation and Mobius Institute, describes the reality of plant life, he's drawing on what this community has shared across decades of training rooms, conference floors, and technical forums.
"You're tired of waking up at 3 AM because something's broken. Tired of machines surprising you when they fail. Tired of having to rely on a team that never stays engaged because they're constantly repairing things. Tired of arguing with procurement. Tired of justifying what you already know."
That’s what Noria hears from practitioners every year, and it's backed by data that puts real numbers to what plant professionals already experience firsthand. A 2023 ABB survey of more than 3,200 global plant maintenance leaders found that over two-thirds of industrial businesses experience unplanned downtime at least once a month, at an average cost of $125,000 per hour. Siemens' True Cost of Downtime 2024 report calculated the annual toll on the world's 500 largest companies at $1.4 trillion — 11% of their combined revenues.
Behind every one of those numbers is a team doing its best inside a system that underinvested in the discipline most likely to prevent the problem.
Lubrication Is the Lever
So what does good lubrication practice actually control? More than most budget conversations acknowledge.
Whether a machine reaches its designed service life or fails years early. Whether an electric motor runs at peak efficiency or bleeds energy continuously. Whether a maintenance team spends its time building toward something or perpetually catching up. Follow that chain far enough and you're talking about plant culture, operational margins, and the difference between a facility that leads its industry and one that's always a breakdown behind.
"The more I learn about lubrication, the more I realize how it is in everything," Fitch says. "Nothing can move without considering tribology. It's incredibly important, and yet it gets a back seat to everything else because it isn't considered attractive."
The scale of the opportunity is worth naming directly. Industrial electric motors consume roughly 30% of all electricity used across industry. The efficiency gains available through better lubrication decisions, compounded across motors, gearboxes, bearings, and hydraulic systems throughout a facility, represent a significant and largely untapped source of cost reduction and energy savings.
"That's what I'm excited about moving forward," Fitch says. "How much lubrication relates to the environment, energy conservation, the bigger picture of how our industry operates. We have so much opportunity to improve efficiencies and become more profitable by focusing on lubrication."
For practitioners who have been making this case internally for years, ML'26 is the place to sharpen that argument, gather the evidence, and bring it back to the people who need to hear it.
What Happens When Someone Takes It Seriously
Noria has watched this pattern repeat itself across industries and geographies for 30 years. A practitioner invests in their knowledge. They implement a change. A machine that used to fail every eight months makes it to eighteen. The savings get noticed. Leadership starts listening. The program grows.
"It could be small steps that led to bigger steps over the years," Fitch explains, "but that was because someone took it seriously. They moved from having little awareness of what lubrication was about, to becoming a lubrication technician, then a lubrication champion, then a reliability engineer, then a plant manager. These advances happened because they understood what really keeps machines running and where the money comes in and where it goes out."
What accelerates that arc? Credentials the industry formally recognizes. ICML, MIBoC, and STLE certifications signal genuine expertise to employers and leadership teams. ICML’s newer LAT pathway — Lubrication Apprentice Technician — opens that door earlier in a career, allowing practitioners to begin formalizing their knowledge without waiting years to qualify.
When one person on a team raises their standard, others follow. Programs get built instead of improvised. Culture shifts. The ripple effect of a single committed practitioner, given the right tools and the right community, is something Noria has documented hundreds of times. ML'26 is where that decision gets made and that momentum begins.
Woodgrain Team
From left to right: Les Patterson (Lubrication Technician), Mike Thurston (Lubrication Technician), Kevin Ingerson (Leader Lubrication Technician)
A Conference That Was Always Needed — Is Finally Back
Noria launched the first standalone Machinery Lubrication Conference in 2018 with a straightforward premise: lubrication deserved its own event, not a track inside a broader reliability program. Every session, every exhibitor, every conversation in the building would be built around this discipline and nothing else.
The last standalone ML Conference ran in 2019. Lubrication has maintained a presence at Reliable Plant Conference since then, and that community never stopped showing up. But the question Noria kept hearing was consistent: when is ML coming back on its own?
"There needs to be a dedicated event," Fitch says. "Reliable Plant will always have its origins in condition monitoring and reliability, and it's an incredible event for that. But lubrication needs its own stage."
This October, it gets one, and it gets it in Tulsa, Noria's hometown, where Machinery Lubrication magazine was founded, where the training programs were built, and where 30 years of technical content was researched and published. The location is a statement about roots and about commitment to the community that kept asking for this.
Two full days. Practical sessions built around real plant challenges. Case studies from professionals who have implemented programs and measured results. An exhibit floor where every solution provider and product manufacturer is there because lubrication is their focus too, not a side conversation. Everyone in the building is there for the same reason.
Img 29 ML Conference
The Magic That Happens When the Room Comes Together
What does it feel like to walk into a room where everyone already speaks your language?
For most lubrication professionals, it's not a common experience. In the average plant environment, they are the ones carrying the knowledge, making the case, doing the work without much backup. Walking into ML'26 means being in a building where no one needs an explanation of why contamination control matters, or what happens to a bearing when a grease gun is used incorrectly, or why the filter change interval isn't a suggestion.
"If you come with at least one other person from your team, the conversations between sessions become just as valuable as the sessions themselves," Fitch says. "The things you're hearing together from speakers, from exhibitors, from someone you meet in the hallway. You become better teammates, better colleagues, truly working toward a common mission. That's probably the most special thing you can be part of in an entire career."
Bring the problems your team back home needs solved. Walk the exhibit floor with a specific machine challenge in mind. Talk to speakers after their sessions. That's exactly why they're there. The knowledge you carry home matters. The coalition you build while you're there may matter more.
For solution providers and exhibitors, the dynamic is equally direct. Every attendee on that floor is a lubrication-focused professional with real challenges and real decisions to make. The quality of those conversations is what distinguishes ML'26 from a general trade show.
Img 100 ML Conference
This Is Your Event
You've built a lubrication program, a maintenance standard, a level of expertise that took years to develop — often in an environment that didn't fully recognize what it was worth. Noria has spent 30 years alongside practitioners doing exactly that work. Training them, publishing the knowledge that supports them, and building a community around the discipline they've dedicated their careers to.
ML'26 brings that community together in one place, with programming built around the work you do, exhibitors invested in your outcomes, and a room full of professionals who have been fighting the same fights and earning the same hard-won wins.
Is it worth two days in October?
For anyone who works with lubricants, who wants to sharpen their skills, build their credentials, strengthen their program, or simply be in a room that was built entirely for them — the answer is straightforward.
Machinery Lubrication Conference & Exhibition. October 27–28, 2026. Tulsa, Oklahoma.
We'll see you in Tulsa.
Learn More
References:
[1] ABB "Value of Reliability" Survey (2023)
[2] Siemens "True Cost of Downtime 2024"
