10 Lubrication Mistakes You Can Fix Immediately for Free
Lubrication Coins Header
Lubrication failures are often blamed on oil quality, machine age, or supplier issues. In reality, most failures originate from small, routine mistakes in storage, handling, and equipment care — errors that quietly reduce reliability and shorten equipment life. The good news? These mistakes can be corrected immediately, at little to no cost, with awareness, discipline, and simple actions. Let’s explore them step by step.
Mistake 1: Improper Oil Drum Storage
Why it matters:
Drums stored vertically outdoors accumulate water around the bung openings. Thermal expansion and contraction (“breathing”) can draw moisture into the oil. Water and rust particles reduce additive efficiency, accelerate oxidation, and shorten oil life — eventually impacting machine performance.
Practical Solution:
  • Store drums horizontally with bung and vent at 3 and 9 o’clock.
  • Keep drums under cover.
  • Follow First In, First Out (FIFO) rotation.
Mistake 2: Assuming New Oil Is Clean
Why it matters:
Even fresh oil may contain microscopic particles or water from transport and storage. Using unfiltered oil in hydraulics or servo systems can cause early component wear, valve sticking, and reduced reliability.
Practical Solution:
  • Filter new oil before filling critical systems.
  • Allow drums to settle so contaminants separate naturally.
Mistake 3: Using Shared Containers
Why it matters:
Shared containers can mix residual oil, causing additive incompatibility, viscosity changes, foaming, and potential seal failures.
Practical Solution:
  • Assign dedicated containers for each lubricant type.
  • Clearly label them.
  • Keep sealed when not in use.
Mistake 4: Not Cleaning Grease Nipples
Why it matters:
Dust and dirt entering bearings during greasing cause abrasive wear, vibration, and reduced bearing life.
Practical Solution:
  • Wipe grease nipples before greasing (leave a small dollop of grease after application to act as a seal).
  • Keep grease guns clean and stored in dry areas.
Mistake 5: Top-Up Without Investigating Root Cause
Why it matters:
Low oil levels are often topped up without understanding why they dropped. This hides underlying issues like leaks, seal wear, or contamination, potentially leading to premature equipment failure.
Practical Solution:
  • Investigate the reason for oil loss before topping up.
  • Check for leaks, evaporation, or contamination.
  • Only add oil once system health is confirmed.
Mistake 6: Sampling From Drain Points
Why it matters:
Drain points contain settled debris and sludge. Sampling from these points gives misleading oil analysis results and may lead to unnecessary oil changes.
Practical Solution:
  • Use live-zone sampling ports.
  • Flush valves before collecting oil to ensure accurate readings.
Mistake 7: Leaving Fill Caps Open
Why it matters:
Open reservoirs allow dust and moisture to enter, increasing particle counts, accelerating wear, and shortening oil life.
Practical Solution:
  • Open reservoirs only when necessary.
  • Close immediately after equipment care activities.
Mistake 8: Ignoring Minor Leaks
Why it matters:
Even small leaks allow air and contaminants to enter continuously, accelerating oxidation and component wear. Ignoring them may lead to bigger failures.
Practical Solution:
  • Treat leaks as early warning signs.
  • Inspect and seal them immediately.
Mistake 9: No Breather Inspection
Why it matters:
Clogged or damaged breathers and vent caps allow unfiltered air into reservoirs during thermal breathing, contaminating oil and reducing its life.
Practical Solution:
  • Inspect breathers regularly.
  • Replace clogged or damaged units.
  • Ensure fill points are properly sealed so that air intake occurs only where it’s supposed to: through breathers.
Mistake 10: Lack of Lubricant Identification
Why it matters:
Machines without clear labels risk wrong oil or grease application, causing additive clash, viscosity mismatch, seal swelling and premature system failure.
Practical Solution:
  • Label machines with oil grade, viscosity and change interval.
  • Assign dedicated grease guns.
  • Train staff to verify lubricants before use.
Correcting these small mistakes when you find them only requires an attentive eye during routine plant maintenance. Fixing these errors may cost nothing other than a little time, but doing so can dramatically improve reliability, oil life and overall plant performance.
With awareness and discipline, improvements like these can begin immediately.
