Why is Getting Lubrication Right So Important?
Trae Barentine, Noria Corporation
Foundations of Lubrication Header
Lubrication is one of the most common maintenance tasks in any industrial plant, yet it’s also one of the most misunderstood. Greasing a bearing, topping off a gearbox, or checking an oil level seems simple. Because of that, lubrication often gets treated like a basic routine rather than a precision activity. Many facilities underestimate just how often lubrication sits at the root of chronic failures. When teams perform RCFA on repeated breakdowns, lubrication errors (wrong product, wrong amount, wrong interval) surface far more frequently than some exotic mechanical problem. This can be very tricky to detect: lubrication mistakes rarely announce themselves in real time, they usually accumulate slowly and quietly until damage becomes unavoidable. The sobering reality is that a large percentage of industrial equipment failures can be traced back to poor lubrication practices. Proper lubrication isn’t just important—it’s necessary.
This is made more difficult by the fact that lubrication problems rarely get labeled as lubrication problems because the root cause is never identified. Instead, they show up in maintenance logs as bearing failures, worn gears, overheated motors, leaking seals, or unplanned downtime. By the time the equipment comes apart, the connection to lubrication has often been forgotten. On paper, the PM was completed. Grease was added. Oil was changed. But the details behind those actions are what determine whether lubrication helps or harms equipment life. This disconnect can be made worse if regular lubrication tasks rely on tribal knowledge rather than well-documented procedures. One technician may apply grease until he “feels” resistance. Another may top off oil based on the sight glass alone, unaware the machine must be running to give an accurate level. Over time, these inconsistent practices will institutionalize errors, allowing them to persist for years.
To understand why lubrication matters so much, it helps to understand what a lubricant actually is. Lubricants are not just “oil” or “grease.” They are a blend of components designed to work together under specific conditions.
At the core of every lubricant is the base oil. This is the part that does the actual lubricating. Its job is to form a film between moving metal surfaces, reducing friction and wear while helping carry load and manage heat. Base oil makes up the majority of the lubricant and has the greatest influence on viscosity, temperature performance, and overall service life. Base oils may be mineral, synthetic, or bio-based (i.e. vegetable), and the correct choice depends on load, speed, temperature, and operating environment. For example, synthetic oils often provide superior oxidation stability, better cold-start performance, and longer service life. However, they’re not automatically “better” for every application; in some low-speed, high-load environments, a high-quality mineral oil may perform just as well at lower cost. The important point is intentional selection—not assuming that “oil is oil” and that one category fits all equipment.
Blended into the base oil are additives. Additives improve performance and protect components when conditions become demanding. Anti-wear and anti-scuff (formerly extreme pressure) additives protect surfaces when loads are high and the oil film becomes very thin. Rust and corrosion inhibitors protect metal from moisture and acids. Oxidation inhibitors slow down oil degredation when the lubricant is at risk from oxidative elements like elevated moisture, heat, air contamination or wear particles. These additives are designed to function as a system, which is why mixing lubricants can lead to unexpected problems. Incompatible additive packages can dilute or interfere with one another, reducing protection. When incompatible oils are mixed, you may see accelerated varnish formation, foaming, filter plugging, or even complete additive dropout. These failures often mimic mechanical wear, leading teams to misdiagnose the true cause and repeat the same mistakes.
When the lubricant is a grease, there is a third component: the thickener. Grease can be thought of as oil held in place by a thickener, like a sponge holding water. The oil still does the lubricating, but the thickener controls consistency and how the oil is released to the component. Thickener type also affects water resistance, temperature limits, and compatibility. Two greases that look similar may use different thickener systems such as lithium complex, polyurea, or calcium sulfonate. Mixing incompatible greases can cause them to harden, soften, or release oil improperly, which often leads to bearing damage.
Even when the correct lubricant is selected, its performance depends heavily on its environment. Contamination is one of the fastest ways to destroy both lubricant and equipment. Dirt particles create abrasive wear. Moisture promotes corrosion and accelerates oil oxidation. Process debris and chemicals can further degrade lubricant properties. Unfortunately, contamination often enters through everyday practices: open containers, dirty transfer tools, unsealed storage, or grease guns that are never cleaned. From the equipment’s perspective, contamination from poor handling is no different than contamination from a failed seal. This is why world-class programs treat contamination control and clean, organized storage and transfer equipment as a non-negotiable. Sealed, color-coded containers, dedicated filter carts, and breathers on bulk tanks dramatically reduce the amount of contamination introduced before the lubricant ever reaches the machine. A clean lube room is often one of the most visually obvious differences between reactive and reliable plants.
Another common issue is over-lubrication. For instance, it’s easy to assume that more grease equals more protection, but the opposite is often true. Excess grease creates internal resistance as rolling elements push through it, generating heat. In turn, this heat causes grease to break down faster. Excess pressure during greasing can also damage seals, allowing contaminants to enter. When too much grease is added, the grease meant to protect the bearing can become the source of its failure. Bearings require the correct amount, not the maximum amount. Many facilities now use ultrasound-assisted greasing to prevent this exact problem. Instead of pumping an arbitrary number of shots, technicians apply grease until the ultrasound signature drops, indicating the bearing has reached optimal lubrication. This simple shift reduces both failures and lubricant consumption.
Viscosity is one of the most important properties when selecting a lubricant. It describes how thick or thin the lubricant is and determines whether a protective film can be maintained between surfaces. If viscosity is too low, the film cannot support the load and surfaces come into contact. If viscosity is too high, the lubricant may not flow properly, causing heat buildup and energy loss. Viscosity selection must consider load, speed, and operating temperature, which is why OEM recommendations are a critical starting point. Operating temperature plays such a huge role that some machines effectively change viscosity grades seasonally, just like our cars. A lubricant that performs well in summer ambient conditions may become too thick during winter startups, leading to boundary conditions and unnecessary wear.
Machines operate under different lubrication conditions. In full-film lubrication, a complete oil film separates machine surfaces, resulting in minimal wear. In elastohydrodynamic lubrication, (typical in rolling element bearings and gears) the film is very thin but the high pressure at the point of contact causes the lubricant to temporarily increase in viscosity and protect the surfaces. Boundary lubrication occurs when the film is too thin to fully separate the moving parts. Protection then depends largely on additives, which is one reason why proper additive selection is very important. Boundary conditions are common during startups, shutdowns, and heavy loads — exactly when equipment is most vulnerable.
Oil and grease each have their roles. Oil can circulate, remove heat, and be filtered, making it ideal for gearboxes, hydraulic systems, and turbines. Grease stays in place, making it useful for bearings and locations where relubrication is less frequent. However, grease does not dissipate heat as effectively and must be applied carefully.
The most effective lubrication programs treat lubrication as precision maintenance. Every task should define the correct lubricant, correct amount, correct location, correct interval, and correct method. In advanced reliability programs, these parameters are documented in the CMMS and validated through oil analysis, ultrasound, and other condition-based monitoring tools to support predictive and prescriptive maintenance strategies. When these variables are controlled, equipment performance becomes more predictable and failures decrease. When they are not, problems develop quietly until a failure forces attention. Truly exceptional lubrication programs also employ predictive tools like oil analysis. Routine oil sampling provides a window into the machine’s internal condition. Viscosity drift, rising particle counts, water contamination, or additive depletion signal problems long before they become failures. Plants that fully embrace predictive tools often catch early-stage issues such as improper top-offs, ingressed moisture, or early bearing fatigue, all while extending drain intervals safely.
Lubrication may look simple, but its impact is anything but. When done correctly, it reduces wear, controls heat, protects against corrosion, and extends equipment life. When done poorly, it shortens component life and increases downtime. The difference comes down to understanding the lubricant, controlling contamination, and applying it with purpose rather than habit. The simple truth is that lubrication isn’t a side task; it’s one of the most important reliability practices in the plant. When maintenance teams embrace lubrication as precision work, the payoff is measurable: longer equipment life, fewer failures, lower energy consumption, and more predictable operations.
