As maintenance teams work to reduce downtime, increase reliability, and support more sustainable operations, traditional oil analysis is no longer enough. Today’s maintenance programs require tools that can report current oil condition and also forecast how that condition will change over time. To explore how AI is advancing this shift, we spoke with Lisa Williams, Digital Product Manager at AMETEK Spectro Scientific. Lisa has been at the forefront of bringing true forecasting capabilities into the oil analysis space through the TruVu360 platform. AMETEK Spectro Scientific is now preparing to expand these capabilities with a new feature called Fluid IQ, which applies historical oil data to determine how often a plant should sample, when an oil is trending toward failure, and the most efficient drain interval for each asset. In this interview, Lisa explains how AI forecasting is helping maintenance teams move from reactive decision-making to forward-looking strategies that improve asset health, reduce waste, and strengthen long-term reliability planning.
Q1. How do forecasting models differ from traditional oil analysis methods in predicting optimal oil change intervals?
Lisa: I’ve been working in the industry for 20 years, and for those 20 years I have been using the term “predictive maintenance”. What I like now with these new models is that we’re truly entering that phase. We’re learning the difference between using data from the past to predict what may happen versus this forecasting model that is using historical data to develop models to predict what is going to happen in the future.
Traditional oil analysis is diagnostic by nature. It tells you what has already happened and whether something is outside a limit right now. Forecasting models are very different. They project forward. Instead of just saying, “Your viscosity is normal today,” a forecasting model looks at the rate of change, the historical patterns, and the equipment’s operating context to predict how long the oil will stay within acceptable limits. What we’re ultimately doing is answering the question maintainers actually care about: “When will this oil realistically need to be changed?” That simply isn’t possible with static alarm limits or traditional reporting.
Q2. What are the main challenges maintainers face today when trying to forecast oil drain intervals using oil analysis data?
Lisa: There is a real challenge facing maintenance professionals. When you draw a sample and the condition comes back normal, the question you come up with is: “OK, what does that mean for the future? Do I extend my drain interval? Do I sample again? What happens?”
If a sample comes back perfectly normal halfway through a recommended interval, you don’t really know whether that oil can safely run twice as long or whether you’re about to hit a rapid degradation point. Another issue is that labs rarely give clear direction. You might get a comment saying “continue to monitor” or “resample in X hours,” but almost never “your ideal interval is Y.” And then there are regulatory barriers, especially in generator applications, where you’re not allowed to extend an interval without solid, documented condition-based evidence. All of this leaves maintainers guessing, even when they have years of data in front of them.
Q3. How does AI-powered, real-time, on-site oil analysis empower non-experts to make effective maintenance decisions?
Lisa: TruVu360 was designed with the non-expert in mind. The alarms are already preset (though they can be edited by the user) and the diagnostic statements auto-populate on a nice final report.
With AI interpreting the data, the system automatically translates results into clear guidance: what’s happening, what it means, and what you should do next. Instead of digging through numbers or comparing plots, the user sees a straightforward explanation and a recommended action. The workflow is intuitive enough that even newer technicians can make confident, informed decisions.
Q4. What role does historical data play in training forecasting models for oil degradation, and how does this improve predictive accuracy?
Lisa: Having a dataset of your equipment and oil analysis measurements is critical. A model can’t forecast behavior it’s never seen. TruVu360 draws from a huge global database of anonymized oil samples, and the more data we collect, the better our predictions become.
On-site oil analysis users utilizing the cloud ecosystem are ideal candidates for improving predictive accuracy because they provide consistent runtime and maintenance context- technically valuable input that can be relied upon. This lets the model understand not just degradation rates, but how they behave under different loads, duty cycles, and climates. With every sample, the model gets a little better at seeing the future.
Q5. Can you explain how the TruVu360 AI Forecasting platform translates uninterpreted oil analysis results into actionable maintenance recommendations?
Lisa: Behind the scenes, the system uses advanced statistical modeling ( think Markov Chain Monte Carlo approaches) to digest the raw data. But the user never sees the math. What they see is a clear statement about the asset and a specific recommendation: when the oil should be changed, when the next sample should be taken, and whether there are any risks trending upward. The platform connects diagnostics to actions and actions to outcomes, so you have a closed loop that improves over time. We’re really going beyond the diagnostic at this point—if you don’t need to take any action now, this is what you will need to do in the future.
Q6. What are the risks associated with extending oil drain intervals without proper monitoring, and how do TruVu 360 Fluid IQ tools mitigate these risks?
Lisa: Extending intervals without monitoring is essentially running blind. You might save oil in the short term, but you risk increased wear, reduced reliability, or even catastrophic failure. However, forecasting does not mean always the word extending. Heavily used assets might actually need more frequent change, so you’re in this situation where you have a risk of over- or under-servicing. Sometimes the model will say, “Yes, you can safely run longer.” Other times it will tell you, “Actually, based on this environment and load pattern, you need a shorter interval than the OEM recommends.” It protects the asset either way by grounding the decision in real data.
Q7. How do climate and operational environment factors influence the accuracy and reliability of TruVu 360 Fluid IQ recommendations?
Lisa: Climate and environment where equipment is working impacts oil life, often shortening it much earlier than what the OEM recommended. High heat climates accelerate oxidation. Cold climates introduce condensation issues. Dusty operations introduce abrasives. When you look at where the equipment is operating, you start to build a dataset that shows what conditions are reducing the expected drain interval. In industries like food and beverage, for example, facilities are required by FDA guidelines to power wash their equipment regularly. That constant exposure to water significantly increases the risk of water ingression in gearboxes, conveyor drives, and other rotating machinery, and that has a direct impact on how quickly the oil degrades. Forecasting models need to account for those variables, and TruVu360 allows users to build environment-specific alarm profiles that reflect the real world the asset lives in. When you tune the model to the environment, its predictions become significantly more accurate.
Q8. How does forecasting enable quantitative, data-driven recommendations for sampling and oil changes compared to blanket OEM guidelines?
Lisa: OEM guidelines are designed for controlled testing environments, not the field. Forecasting looks at the actual rate of change in your specific equipment and gives you a data-based interval, not a generic time or distance-based number written for warranty protection. It also recommends how often you should sample based on real degradation rates instead of arbitrary schedules. This gives reliability teams something powerful: defensible decisions rooted in statistically modeled behavior rather than intuition.
Q9. Your team recently completed a pilot with a large mining fleet in South America that relied heavily on fixed OEM intervals. Can you walk us through what that case study revealed about safely adjusting oil drain intervals and reducing maintenance costs?
Lisa: When we piloted the TruVu360 Fluid IQ with a mining fleet in Chile, the results showed very quickly that a one-size-fits-all drain interval wasn’t working. Those 13 haul trucks were locked into a 600-hour OEM interval simply because they were hundreds of kilometers from the nearest lab, and that was the safest thing they thought they could do. Once we applied TruVu360 forecasting, more than half the engines showed they could safely run beyond 600 hours without any impact on performance. But a few of them were actually degrading much faster, and those intervals needed to be pulled forward, not pushed out. That was one of the biggest lessons: forecasting isn’t just about extending. It’s about getting the interval right for each machine.
The cost savings came not only from the safe extensions, but also from catching the early degraders before they turned into unplanned downtime. And another unexpected benefit was the sampling strategy. The model told them exactly when they should pull the next sample, which was a huge improvement when you’re that far from a lab. It completely changed the way they planned maintenance.
Q10. How can forecasting support sustainability and ESG goals in lubricant condition monitoring programs?
Lisa: Optimized intervals reduce oil consumption, waste disposal, transportation, and the carbon footprint associated with unnecessary servicing. At the same time, improved reliability means equipment lasts longer and runs more efficiently. For companies with ESG targets, lubrication is one of the easiest operational levers to measure and improve, and forecasting gives you the data to show exactly how those improvements are being achieved.
Q11. What are the next frontiers for forecasting in oil analysis, especially around Remaining Useful Life and risk-based monitoring?
Lisa: We’re moving toward even more precise RUL predictions that account for specific failure modes, environments, and usage patterns. Beyond that, the future is risk-based monitoring which means quantifying not only when something might happen, but the probability and potential impact of the event. That allows maintenance teams to prioritize work based on actual risk instead of rigid schedules. Ultimately, forecasting will become a core engine inside broader asset performance management platforms, feeding work orders, maintenance planning, and long-term reliability strategies automatically.
Bottom Line
AI forecasting is rapidly reshaping oil analysis by helping maintenance teams understand not only the current condition of their lubricants, but also how those conditions are likely to change in the future. TruVu360 is already supporting this shift, and the upcoming Fluid IQ feature will enhance it even further by using historical oil analysis data to predict sampling needs, anticipate when oil is moving toward failure, and guide plants toward fully optimized drain intervals. Organizations that invest in these capabilities now will be better positioned to prevent failures, improve reliability, reduce waste, and meet their long-term operational and sustainability goals.
To learn more about TruVu360, Fluid IQ, and the full range of on-site oil analysis solutions, visit AMETEK Spectro Scientific at https://go.spectrosci.com/truvu-360-ai
Lisa Williams is a maintenance and reliability professional with nearly 20 years of experience working in tribology and reliability engineering. Specializing in lubricant condition monitoring, she currently serves as the Digital Product Manager at AMETEK Spectro Scientific. She holds multiple industry certifications including STLE CLS and ICML’s LLA II. She also serves as chair of ASTM D02 CS96 Subcommittee on lubricant condition monitoring testing. She has published dozens of articles and papers related to building and maintaining condition monitoring programs. Lisa also holds a BS in Chemistry and an MBA.
