In the construction industry, hydraulic systems are pushed to their limits every day. Dust, dirt, moisture, extreme temperatures, and demanding operating conditions create the perfect environment for contamination to enter machinery and accelerate component wear.
When hydraulic cleanliness is not properly controlled, it can result in premature component wear, unexpected downtime, expensive repairs, and reduced productivity across the jobsite. In this webinar, we’ll explore why contamination control is critical for protecting construction equipment reliability and performance.
Key topics include:
- Why contamination is a leading cause of hydraulic system failure
- The hidden costs of downtime and component replacement
- Common warning signs of hydraulic system problems
- How contamination issues can multiply across an entire fleet
- The role filtration plays in protecting pumps, valves, and hydraulic components
- Practical strategies for improving hydraulic cleanliness and equipment reliability
Whether you oversee a small equipment operation or a large construction fleet, this webinar will provide actionable insights into reducing hydraulic failures and improving machine uptime through effective filtration practices.
Join the broadcast on June 17 @ 1pm Central
